Wet carpet LHD
Wet carpet LHD
Hi. I've looked at the threads about the wet carpet thing. People talk about the " driver's side " meaning the right hand side if you're sitting in the car. My 406 is left hand drive. and the driver's side , left hand side, footwell carpet is soaked. Do those vulnerable electrical connections change sides depending on lhd or rhd or are they always under the right hand side carpet ? I ask because it's been chucking it down here in Portugal , my left side carpet is soaked and I'm having a couple of minor electrical problems.
Re: Wet carpet LHD
Here too, suffering the torrential rain...
Interesting question, I had a look into my SEDRE system and it looks like the footwell connectors are indeed at the driver side, whether LHD or RHD:
From my experience, the wet footwell is caused by water which flows along the driver door window and then leaks through the splash guard behind the door panel. The splash guard is a white foam type sheet that you see when you remove the door panel. It must not be torn and it must be sealed to the door metal at least at the bottom and sides. When doing repairs inside the door, the seal often gets damaged. Best way to test if it is watertight is to open the door, put a screwdriver between the window and the rubber seal and then pour water along the created opening. If all is well you see the water coming out from the drain holes, not from the bottom of the door panel.
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 690.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
Re: Wet carpet LHD
Hey Frog, you in Portugal too ?
Re: Wet carpet LHD
No, this is the Netherlands. Wet and cold are the only two flavours...
Current "fleet":
Previously owned:
Previously owned:
