Help with airbag plugs please
Lee1978
Post by Lee1978 »
Hi all, i have a 2002 406 and need a bit of help, its a long story but i need someone to take a look at the back of their com2000 and tell me the colours of the wires for their airbag connections. If the 406 is the same as the com2000 i'm looking at there is a blue plug on the bottom left (as you face the steering wheel on the back of the com unit) what colour are the wires going into that blue plug? There will be another plug on the opposite corner, what colour is that plug and what colour are the wires going into it?
2002 2.0hdi 90hp Siemens, de-cat, egr blanked.
frog
Re: Help with airbag plugs please
Post by frog »
This is the diagram I could find on the SEDRE disc for the COM2000 unit for your vehicle (I guessed your DAM/RPO number to be around 9350):
The meaning of the color codes:
BA: white.
BE: blue.
BG: beige.
GR: gray.
JN: yellow.
MR: brown.
NR: black.
OR: orange.
RG: red.
RS: pink.
VE: green.
VI: mauve.
VJ: green/yellow.
6565 is the "driver's air bag module"
6570 is the "air bag and pre-tensioners control unit"
See also http://www.autoelectric.ru/auto/peugeot ... agrams.htm or https://pdfcoffee.com/peugeot-all-model ... -free.html
If you need anything else feel free to ask.
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Maybe the pictures in this thread will help? https://www.406oc.co.uk/viewtopic.php?f=10&t=17391
dirtydirtydiesel
Post by dirtydirtydiesel »
Lee1978,
Sorry for the slow reply, I don't come on here often these days :roll:
Anyway,
I've just screwed mine all back together because of a airbag fault.
I looked at the plugs for you today.
Mine is a 2002 full mux with com2000.
So sat in the driver's seat with the ignition barrel on your right.
It's a brown plug with top wire, Orange with Yellow tracer
Bottom wire, Yellow with Orange tracer.
Left hand side, from the driver's seat
Blue plug with top wire,. Yellow with Orange tracer
Bottom wire,. Orange with Yellow tracer
Now as a side note these wires do have identifying no's on them but I couldn't read mine
(sorry but I wasn't going to disconnect the battery & BSI sleep / reset just to look for that for you).
Hope this helps if you haven't already sorted it.
