Airbag defective error on dash and audio aerial input.
Killerko
Post by Killerko »
As my quest to clear pp2k of all the errors is nearing completion, I still have these 2 to tackle:
The airbag one was kinda intermittent before but now it's 100% there... accompanied with airbag defective message on display when ignition is turned on.
I have never dealt with any airbag issue before, will I have to replace the whole thing or is there any chance something else is just loose?
And one more error that I have is the audio aerial input.
When I bought the car it was missing the aerial tip in the back and traffic alerts were not working.
But I have replaced the missing tip and traffic alerts now work, yet when I delete the error it will come right back.
Re: Airbag defective error on dash and audio aerial input.
I think the airbag warning is the key switch by the handbrake - these get dirty, dusty, covered in fizzy drinks over the years and can affect the wiring.
Have a look at this switch, use contact cleaner and turn is on and off a few times - it might sort itself out.
If it's not this switch then it could also be the common issues of the wiring under the passenger front seat ( for the pre-tensioner, or the side airbag ) this has been documented here several times - you'll have to use the search function above as I'm off to bed :cheesy:
It's not the drivers airbag as these are trigger 1 and trigger 2 in PP2K.
Sorry, I can't help you regarding the aerial.
Killerko
Post by Killerko »
Well, I moved the passenger seat up and down.. forward and backward, turned the airbag off and on and hey, the error is gone from dash :lol:
Haven't checked with pp2k but I think this one was really simple... will check the cables properly when I get some time, I suspect it's the passenger seat.
Aerial input is the last error remaining.. but it could easily be ignored as the radio is working as expected.
frog
Post by frog »
I've always had the audio aerial input fault (since the first time I connected PP2000). Radio has always worked fine, so I'm ignoring it.
I also had the airbag faults, they are always related to a bad connection (a brown connector plug iirc, under the seats). It is a flimsy plug that wiggles and wobbles and does not give a very stable connection.
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
