My 406 has some wired problem where sometimes driver side door won't unlock with remote key but lock is working. But the center lock works just fine. If the key is put into door it will unlock and lock without any issue.
What could be the issue?
406 D9 1999 L6A
Driver side door sometimes not unlocking from the remote key
Re: Driver side door sometimes not unlocking from the remote key
What do you mean with "center lock"
if the door does always unlock when you operate (or "help" operate) it mechanically, I think the mechanism needs some oiling, e.g. with ample WD40.
Current "fleet":
2003 406 Estate 2.0HDi 110 - 7 seater - just hit 690.000 kms
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
Previously owned:
Center lock works means, when I put my key into car and tried to unlock it unlocks and locks just fine.
you mite need to change battier in fob , if that dont work then re sink key with car . put key in turn on hold lock button for 10 seconds then turn key back and take key out , wate 20 secondes then try key
I suspect that's what Frog means by operating it manually. Hopefully it is just stiff and soaking it in WD (or similar) will sort it out. Other than that the solenoid might be on its way out or there's an electrical fault (wires going from the pillar into the door are good at this) but start with the easy stuff first.
Thank you will check and tell you.steve_earwig wrote: ↑Mon Feb 07, 2022 7:06 amI suspect that's what Frog means by operating it manually. Hopefully it is just stiff and soaking it in WD (or similar) will sort it out. Other than that the solenoid might be on its way out or there's an electrical fault (wires going from the pillar into the door are good at this) but start with the easy stuff first.
