ServiceBox alternative
Is there free alternative of PSA Service Box? Since they switched to paid access it is hard to identify parts. One good feature was the box at upper right where I can enter OEM code and the system displays the topics (schemes) where it is used. For the moment I have to replace 1628.HC valve but not sure which one it is. I know there are at least 3 similar valves near to EGR but not sure are they identical and which one is 1628HC. I think there is more than one with this code. There is another valve with almost the same code 1628CH.
Re: ServiceBox alternative
If I remember correctly, all 3 valves on the bulkhead are identical - the one with the CH code is the swirl valve...
If you manage to find a decent replacement part then let me know as I need one to test my vacuum system ( I only have used parts and my ones were found in a box so completely untested )
this works reasonably well as an alternative
https://catalogs.ssg.asia/peugeot/?lang ... vzxPtKL8cU#
Nice find!
Been looking for an alternative since Peugeot put a paywall in front of their ServiceBox.
Thank you trem1.
Thank you trem1.
2003 HDi, 90HP (DW10TD), saloon D9, 5 speed manual (ML5C), silver met (EZR).
