New EGR valve
New EGR valve
Is there any benefit of replacement of EGR valve with brand new instead of removal and isolation?
Re: New EGR valve
No.
You can remove it to clean it out if you are having trouble with it - it gets bunged up with exhaust crud and then the vacuum operated plunger gets jammed open, or closed....
