Hi guys and girls.
I am looking to get an online remap from hdi tuning for my hdi 90.
I see they recommend the MPPS tool for this.
Is this the best option or PP2000.
I see a lot about PP2000 on this forum but maybe it’s just for diagnostic work and not ecu flash?
Thanks again,
Andrew
PP2000 or MPPS for remap HDI tuning
2001 HDI 90bhp - current daily
Re: PP2000 or MPPS for remap HDI tuning
You can't reprogram the ecu with PP2000, you need MPPS or another flash programmer.
Many of us have used the old Galleto 1260 for 406's with BOSCH ecus, but your HDi 90 maybe a Siemens unit - I don't know what you need for them.
The Siemens can only be mapped by sending your ecu to hdi tuning or you can buy a
ecu direct from them that's unlocked.
2002 110 HDi estate, Rapier in monaco blue! ( found quite a bit more power ) SOLD I've sorted the airbag light
2006 206 1.4 16v sport in Aegean blue ( wife's shopping trolley )
2006 BMW e61 535d m-sport run's for cover
Hi Andrew.
As you have already said, PP2000 is for diagnostics only ( although it can do more it isn't a flashing tool )
Doggy has used his Galletto several times on my previous 406s without issue - although we are always cautious - however they have all had the Bosch ECU which is a doddle to do.
If yours is indeed the Siemens ECU ( the Hdi 90 can have either Bosch or Siemens ) then your best bet would be to get an off the shelf ready made ECU which will be plug and play, plus no future immobiliser issues if your car suffers from water ingress too
You are looking at around 120bhp with one of these ECUs - a vast improvement over the standard 90.
Contact Hdi tuning, have a chat and see what they can do - they are a good bunch, very approachable and experienced.
i have a siemans ecu on my car 90 hp rhy with maped ecu that takes it to 120 make so much different . i was guner go up to 150hp map stage 2 but need other mods yet
stage 1 ive got k&n filter decat and strate throw exhaust
the mpps tool can be used to map the ecu.
you can use the online service and program using MPPS
email on [email protected]
You can fit the intercooler and pipes from an Hdi110 but you'll need to either buy the cooling fan shroud to go with it, or cut the blanking plate out....
The turbo itself is purely mechanical, not ECU controlled, so that's less wiring to sort out
