PP2000 midlands / northants / MK ?
6speedmanual
Post by 6speedmanual »
Hi All
Just wondering if there is anyone with a PP2000 near to me in Northampton.
I hope to be able to interogate the settings status for cruise control activation.
My car in an 03 with COM-2000. Cruise stalk and additional brake pedal switch are now fitted.
When I had my car mapped by HDI Tuning, he stated that the Cruise function was recognised by the ECU. But that was before the stalk and switch were fitted. Maybe other checks / settings are required?
Thanks in anticipation
Re: PP2000 midlands / northants / MK ?
Hi Peter.
Is the cruise control stalk clicked into place?
Also you may need to adjust the extra pedal switch to come on the right time - this is where PP2000 works wonders 8)
There are a few members near Northampton with the set-up.
Doggy is in Corby - not sure if he still has the gear though.
DDD is in Coalville, and a chap called Tony is in Ravenstone - both very competent.
Hope you get it sorted.
Kelv
I still have the 'gear' and could have a butcher's for you.
IIRC it needs to be enabled in the BSI in two places and the two brake pedal switches have to operate in a specific order as you press and release the pedal.
Unfortunately I no longer have a working 406 to compare with. :(
