406 scanning codes
NinoB
2.2 16v
406 scanning codes
Post by NinoB »
hi guys
my car do always show engine check and when ever i scanned it, i will see these code:
Engine ECU: Permanent fault. Injection of air to the exhaust Malfunction.
please what is the meaning? and how can i go about it?
regards
NinoB
2.2 16v
Re: 406 scanning codes
Post by NinoB »
can any one at least try to interpret it?
Is this on a petrol engine?
NinoB
2.2 16v
Post by NinoB »
yes its petrol engine, EW10 engine
My last petrol car - a 3.0 Omega - had an electric pump to force air into the exhaust. Purpose was to help combustion of unburned fuel to get the catalytic converters up to working temperature quicker. Only operated when the engine was cold.
I suspect there may be a similar system on your car
NinoB
2.2 16v
Post by NinoB »
where do you think the pump is located? this problem occur when i started the for like few minutes or mostly while am driving, and the car will misfire heavily and power will reduce, while sometimes no misfire it will just appear and show engine sign.
NinoB
2.2 16v
Post by NinoB »
hi peeps
still having this problem:
[[[Engine ECU: Permanent fault. Injection of air to the exhaust Malfunction]]]
its just normal engine ew10 petrol executive.
pls is it the pump that injected air into manifold? the fault keep coming up??
frog
Post by frog »
Service Box shows an air pump as "8" in the following diagram, but i cannot seem to find the PSA part number:
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
frog
Post by frog »
Looking up a 407 in Service Box retrieves part no. 1618E4. But i'm not sure that is the same for a 406.
Hope this helps...
Current "fleet":
Previously owned:
NinoB
2.2 16v
Post by NinoB »
ok brother thanx.. i will find the location in the engine...loose it and service it..if the problem persist i will find a similar part and change it... hope i dont have to loose my gearbox before getting access to air pump
It could just be the fuse for the air pump.
The ecu must "think" the pump is not working - it probably will not measure the pressure or flow, it is more likely to monitor the voltage
NinoB
2.2 16v
Post by NinoB »
but i did actuation test and the pump is working.. so i doubt if its a fues
Sorry, I didn't realise you had carried out the actuation test.
Wiring diagram for the RFN engine shows a "pulsair pump" with only 2 connections, (which must be OK if you can hear it run).
It does have an "induction air pressure sensor", possibly this is how it monitors the pump?
Might be worth checking if you can read the values from this sensor with the engine running
I guess PP2000 does not give any further information if you click on the error message you showed in your earlier post?
NinoB
2.2 16v
Post by NinoB »
where can i locate the induction air pump pressure sensor?
yes the pp2000 does not give a further information about the error.
frog
Post by frog »
Does the fault re-appear after clearing all faults?
Maybe the problem has gone. Some faults are not automatically cleared but need to be cleared manually using PP2000.
Came across this post in another forum that mentioned:
I can only assume that the air ports in the cylinder head are blocked as I made up a fitting and put workshop air into the head via the air pump inlet valve. I removed the upstream O2 sensor and no air was coming out which only leads to one thing and that is the ports are blocked. I will learn to live with the fault coming on every two to three weeks as I am not going to remove the cylinder head to unblock the ports. Hope this helps.
Current "fleet":
Previously owned:
