auto wipers ?
auto wipers ?
Any ideas guys
when I switch to auto it either wipes on single speed or as most of the time does not work at all, its just on auto setting the rest works ok ?
do you think it is the stalk or the sensor ? has anybody had same issues ??
My car is a 2001 110 hdi
Re: auto wipers ?
I think that's more likely to be switch.
Is it com2000?
They must have had a sale on
Re: auto wipers ?
not sure which type of stalk it is ?
do not think it is comm2000
mine has no sat- nav , rain sensor via stalk, button on end for display function
my car was made near the changeover from 109 bhp to 107 bhp ,I think its 107 ??
can you tell without dismantling ??
Re: auto wipers ?
Wot, not 110bhp?
It's easy to tell if you know what you're looking for. Plenty of com2000 pics in this thread viewtopic.php?f=10&t=17391 The point being if it isn't and the stalk's goosed then you won't need to sell a kidney to replace it (if it's beyond fettling). If it is com2000 then it would make diagnostics much easier - if you have access to PP2000 anyway...
The reason I think it's the switch is if the sensor's goosed then it should just fall back to a standard intermittent. The way you describe it seems more like it's either not getting far enough for intermittent to work or it's going too far and putting low speed on.
Re: auto wipers ?
I have a spare stalk here with the button for the trip computer etc..
I bought it for my D8 Coupe ( for trip computer purposes ) but my car has the wrong parts
Re: auto wipers ?
Can't be asked to log in to Service Box (time for bed, kill downloads, find a proxy server that's in the UK, delete cookies, yadda yadda) but I have a feeling you should check the part numbers.
Would also like to be right about it being the switch, rather than only suspecting it...
Re: auto wipers ?
took off the top cowl on the steering wheel and got a valeo part no. 61557024
looks like a combined indicator/wiper thingy
any ideas ??
any ideas ??
Re: auto wipers ?
Hi all,
took sensor off, cleaned it, and when switched to auto there no orange light indication
so need to check if sensor getting power when switched on to see if its the sensor or the stalk
Am I right in thinking if the sensor is u/s the wipers go into default setting ?
When sw to auto more and more just goes to single speed
If going to be expensive will manage as is !!!
Re: auto wipers ?
I think they're meant to go to a default intermittent setting (IIRC I read that over on the coupe klub) but I guess it depends how much is actually wrong with them.
Re: auto wipers ?
Mine have always had a mind of their own
On my full - mux estate & my semi - mux coupe
I'd prefer just good ol fashioned intermittent
2006 BMW e61 535d m-sport
run's for cover
Re: auto wipers ?
Just a thought like back the old days!
Is there a way of tapping into the wiring to fit a switch in circuit to turn on an intermitent wipe ???
Re: auto wipers ?
I see on ebay there is a com2000 repair service for £45 anybody used them ???
Re: auto wipers ?
There used to someone doing it for about £29, but I think they were only replacing the little plastic pin that shears off allowing the indicator stalk to go 'floppy'. (You can buy this bit on its own now for coppers). Suspect neither solution will resolve a faulty wiper switch mechanism.
Re: auto wipers ?
I've used the repair company before - a chap called Graeme Hall.
Good service, reliable and knowledgeable.
Re: auto wipers ?
Known as trustme over on Peugeotforums, lives Bradford area but does a postal service as wellGingerMagic wrote:I've used the repair company before - a chap called Graeme Hall.
Sent from my K013 using Tapatalk
