instrument panel faults 406
duke
Post by duke »
hi all i have an ancient pug 406 lx petrol 1.8 16v 1997 vintage and recall hearing talk somewhere maybe here of a fault that causes instrument panel intermitent faults ie speedo rev counter,fuel gauge etc not working but if you knock the cover it all comes to life for a while is it a case of resoldering or rewiring?i ssem to remember talk of dry solder and some kind of connector any advice gratefully recieved,peace :roll:
PeterN
Re: instrument panel faults 406
Post by PeterN »
Sounds like a dry joint on the PCB. XMs use to suffer from this problem and it was usually the connectors on the edge of the board, they would develop a crack around the soldered joint. Examine the board carefully with a magnifying glass and you might find the problem.
duke
Post by duke »
PeterN wrote: Sat Feb 16, 2019 10:21 am Sounds like a dry joint on the PCB. XMs use to suffer from this problem and it was usually the connectors on the edge of the board, they would develop a crack around the soldered joint. Examine the board carefully with a magnifying glass and you might find the problem.
hi i dont suppose you or anyone knows where exactly the pcb is located and whats required to be removed to get to it?i guess most of the time but dont fancy taking the dashboard apart any more than needed!cheers :mrgreen:
PeterN
Post by PeterN »
Remove the instrument panel then the cover and its right in front of you, the faults are likely to be where the edge connectors plug in, check where the connections are soldered to the board.
archangel2
Post by archangel2 »
what size screws for instrument panel removal guys ? these are the things newbies need to know
duke
Post by duke »
well my instrument panel is still crazy but all i did was tell the mot tester if he has trouble give it a whack and it works after that,passed again and still not found an affordable instrument panel! only notes are minor not bad for a near 24 year old pug with near 200k on the clock
there was a posh porsche in at same time first mot and failed dismally!dont figure aye,peace :lol:
