Fuse box diagram
AndreiNCS
Fuse box diagram
Post by AndreiNCS »
Hi guys,
Do you know if there is a fuse unde the hood ( the box between battery and acceleration module ) responsible for the climate display and info display(consumption, range, etc) ?
I'm asking because those 2 displays are turning on just by opening any door of the car, and they are turning off after few minutes ( 2 or 3 I think) , no matter if the I close the door or lock the car. But if I close the door and wait for them to turn off, after unlocking the car from the key or opening a door, will again turn on the displays( I forgot to mention that they are turning on with a slight closer light, not like the normal light when they were working fine). The climate controls are working fine, but on the above display I got no info about the range, temperature and so on, I only got the clock working. One more thing would be that the temperature setting are getting reset all the time after a turning off.
Back to the fuse box, the car was at a mecanic with other issue, but he said that the displays were working for a few ours after he accidentaly probably hit something in the fuse box, and I know he's right because at first my temp was always reseting at 22 C degrees and now it resets to 29 C degrees because he drove the car in a cold morning?
Any ideas?
Many thanks in advance!
P.S. It's an Peugeot 406 HDi (90HP - RHY )
Re: Fuse box diagram
That sounds a lot like damp connectors under the driver's carpet - http://www.406oc.co.uk/viewtopic.php?f= ... zy#p107150
Some fuse diagrams here http://www.peugeotlogic.com/#fuses but I'm pretty sure all the dash stuff is in the cabin fuse panel.
+1 damp connectors are likely culprit.
I have heard of instances of the main MFD remaining lit up after locking the car, (had it myself once or twice). Can be because the radio/head unit doesn't get powered down, it goes into standby mode which normally looks like it's off but it doesn't truly shut down until the various ecu's go to sleep some minutes later. (Hence the procedure for disconnecting the battery in the KB).
+2 for wet footwell syndrome - it might feel dry on top but a reservoir underneath....
Just to add, if yours is a saloon model then it's possible you have a leaky rear light instead, which is getting the CD changer connection wet ( I think it's a blue plug tucked down the left side boot cubby hole..)
Lastly, try the BSI reset - it's just a way of getting the creature comforts back in communication if there are any issues, not always a solution but it's free to try.
There is a guide on how to do this in the Knowledge Base on the home page.
AndreiNCS
Post by AndreiNCS »
Hi and thanks for your answers, but unfortunately it's not caused by the wires under the carpet because I checked them... apparently seems to be something with the fuse box because the mecanic said that he only worked under the hood, nothing inside the car.
And neither the CD changer is not applicable because I don't have one. It's fitted with tape radio player, wich also broken :D
If it helps, I will post tonight a video with the displays behavior.
AndreiNCS
Post by AndreiNCS »
AndreiNCS wrote: Wed Jan 23, 2019 7:17 am Hi and thanks for your answers, but unfortunately it's not caused by the wires under the carpet because I checked them... apparently seems to be something with the fuse box because the mecanic said that he only worked under the hood, nothing inside the car.
And o more thing I forgot to mention is that the rear windows defrost it's not working either since the clima display problem appeard. I press the button, the icon on display stays on for 1 second and it goes off, and also I can't hear that click sound when turning the defrost on
You might not have a cd changer but you might have the cable, one end plugged into the radio (mux) the other lying in a puddle...
Searching your posts the RPO seems to be 9380, so the car is full-mux. The climate panel and the heated rear screen are run off the BSI, fuses F & C (allegedly :roll: ). What was the mechanic doing under the bonnet?
Seeing as it's broken, I wonder if it would be worth removing the tape player just to eliminate it.
AndreiNCS
Post by AndreiNCS »
steve_earwig wrote: Wed Jan 23, 2019 9:13 am You might not have a cd changer but you might have the cable, one end plugged into the radio (mux) the other lying in a puddle...
https://www.youtube.com/watch?v=f2lVu4q ... ture=share
here it is a video with the behavior.... the displays were turned off one minute before with the temp set at 24 C degrees.... and they will turn off after 2 or 3 minutes....
The mechanic was searching the cause of my 4 year problem with the cold start....I also have one topic on this, but no solution so far....
Any ideea after watching the movie on youtube?
Not really, the BSI is turning it on for some reason. We're back to:
The climate control panel is faulty (unlikely, especially given the trip computer is also faulty)
Something else on the bus is faulty
There are damaged wires somewhere
The BSI is fried (it controls the interior lights, the climate control panel, the trip computer and the heated rear screen, amongst other things)
The climate control settings resetting kind of implies a blown fuse, but that's unlikely as the BSI is managing to turn it on.
