PP2000 help
PeterN
Re: PP2000 help
Post by PeterN »
I have two Lexia/PP2000 neither of which I can get to work although they did when I first installed the software, I am running XP on a laptop, it lets me get as far as entering the model but wont connect so I've given up on it now.
I've been running 406's for about 10 years now and so far have been able to keep them going without the help of the PP2000.
cliffk
Re: PP2000 help
Post by cliffk »
Hi Peter
I now have 2 406's one of which I have had for 8 years the engine management light is on so I thought getting the PP2000 would be helpful on both cars eventually.
hopefully I will get the software running and be able to use it.
I have no idea why the engine management light is on there is no lack of performance its just very annoying, it was on at MOT time and my tester checked the OBD and it flagged low fuel (it wasn't and had not been) he cleared the fault and the light went out only to reappear the next day.
Cliff
dirtydirtydiesel
Re: PP2000 help
Post by dirtydirtydiesel »
I've been running Peugeots & Citroens for over 15 years had pp2000 for the last 6 it's saved me hundreds :)
cliffk
Re: PP2000 help
Post by cliffk »
Not having much luck with the downloads from MrV6 software site.
Lexia- I have got as far as getting the Citroen shortcut icon on my desktop but clicking on that and following the included installation instructions I get to a screen that says validation required I cannot install it further, installation fails every time.
PP2000 I cannot get to the point where I see the Peugeot icon on my desktop, following the instructions I click the InstPC on the list it tries to install then just stalls and freezes.
Gave up on Friday night I am trying to install on a windows XP machine going to give it a rest and then uninstall everything and try again later in the week. :( :(
cliffk
Re: PP2000 help
Post by cliffk »
PP2000 update.....It is up and running :cheesy: :cheesy: :cheesy:
Using my old XP lap top I removed everything I had downloaded / installed, did a fresh download of Lexia and PP2000 from Mrv6's download site and attempted to install again following the supplied instructions, failed and failed again, eventually I noticed a setup file on the list of folders and files in the PP2000 folder (not the one mentioned in the instructions) I clicked on that out of curiosity and things started to happen, it took around an hour to install and it then let me go through the verification procedure as listed on the instructions and all looked good.
Lexia installed quicker and as per the instructions.
I did have to connect the OBD reader cable to complete the installation (to the laptop not the car).
One issue I had was that after the installation the key generator disappeared so I had to find that again before I could generate a key to finalise the installation.
Tried it on the car with the engine management light on today and it flagged a fault (low coolant temp), I know my coolant temp sender is faulty, cleared the fault and management light off.
So looks like my frustration has been down to not knowing I had to install a different file than the one mentioned in the instructions before PP2000 could install.
Hopefully thats the end of this post. :)
Re: PP2000 help
Well done for sticking at it. 8)
At least you're not fumbling around in the dark anymore.
Re: PP2000 help
Well done :cheesy:
It'll save you money, time, and you can also help other Peugeot/Citroen owners local to you with a diagnosis.
