Hi guys
i have diagbox, and a cheap chinese Elm327, which worked perfectly on my Mondeo. But I can get it to connect.
It keeps saying VCI not connected.
Is there a way to make it work, or do I have to buy the Lexia connector?
Diagbox v7.62
Re: Diagbox v7.62
You need the proper interface that plugs into the odb socket in your car, you also need this to set up Diagbox or PP2000...
Re: Diagbox v7.62
Ok thanks. The Elm 327 connects perfectly using autodoctor, but not with diagbox. Thought that I might need a driver. But not.
Re: Diagbox v7.62
The ELM is quite good, and the Bluetooth ones are useful - but a Peugeot is better with Diagbox or PP2000 for more access to options and live data.
