Towbar electrics
trufflehunt
Towbar electrics
Post by trufflehunt »
My friend/neighbour has decided that canal boat life is the one for him, and has bought a boat.
I offered to help him trailer some of his stuff. A little while away , I think.
Any way, I've owned the 406 3+ years now, and have never needed to use either of the twin tow sockets.
When I tested both on another neighbour's trailer yesterday, there was not a flicker of any light.
Any suggestions as to anything obvious to check first ?
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
Re: Towbar electrics
Assuming all you rear lights work, you can't have any fuses gone.
Possibilities:
1. His trailer / trailer board doesn't work.
2. Your earth connection is the only thing that could stop all the lights working, (centre pin IIRC).
3. These things are famous for intermittent / not working if not used regularly. The pins & receptacles corrode and fail to make contact. (Esp. earth see above).
4. Someone might have disconnected your socket(s) from the car's wiring. (You'd only find out by tracing the cable from the black socket to the rear light wiring).
Keep us posted.....
Hi, inside the trailer/car connector are sort of 'Plus' shapes which get squashed and don't connect properly - stick a flat blade in and prise them open a bit to get a snug fit.... 8)
Scotchlocks.
They're nasty cheap things.
trufflehunt
Thanks for replies, chaps. I'll check those out.
Have developed a stinking chesty cold. When I shuffled out to the car, opened the boot,
I had sudden urge to return to the couch, and did so.
Normal service to resume, in a day or two, hopefully.
I've been ill too.. (Manflu) carnt shift it :(
