electric fault
mossy
electric fault
Post by mossy »
My car is a 406HDI Diesel turbo ,the problem I have the immobiliser comes on and if I take a battery lead off and refit it car will start the other problem the car dash board stays lit with the engine stopped and keys out of lock if I press brake pedal dash lights go out ,and yet another the ABS light is on the dash all the time and the air bag light also stays on .These problems started a week ago I also noticed a drip on the offside just above the accelerator pedal this appeared after heavy rain and the car parked on a cambered road .The immobiliser problem is not regular nor is the dashboard lights a regular thing ,the air bag and ABS symbols are on all the time .Got worse the immobiliser is on all the time now so car will not start .
Re: electric fault
Hi there, welcome :cheesy:
Unfortunately this is my first thought - viewtopic.php?f=10&t=12118
PeterN
Re: electric fault
Post by PeterN »
I have had something similar myself and it was all due to water under the drivers side carpet.
Re: electric fault
Hi Mossy, welcome.
My initial thoughts are also water under the drivers side carpet ( big connectors under there and even if the top feels dry, it could be loch ness underneath..!! ) but you say you saw a drip above the accelerator cable, which is where the BSI lives.
The BSI is tucked behind the fusebox and is the 'hub' where most of the electrics talk to each other - if there is water in here then you may have big problems - have a feel around for water.
mossy
Re: electric fault
Post by mossy »
has any Peugeot owners got a wiring diagram for a 406 HDI diesel turbo the wires that are under the carpet on the offside the joint on mine is so corroded by water that a wire has come off and I do not know where it belongs my Email is [email protected]
Re: electric fault
PM sent, but have you checked to see if the BSI is damp - some time with a hairdryer in that area may help.
Re: electric fault
I have diagrams but there are lots of them. Do you have the build code for your car? It might be easier if you pm me your vin...
Can you read the code off of the wire?
