Oil Temp Gauge
RobMorris
Oil Temp Gauge
Post by RobMorris »
Hey guys
Ive noticed that the Oil Temp gauge does not work. The water temp come up to 90c nicely but the oil doesn't budge.
What should I be checking first please?
Cheers Rob
Cosmos Grey 2002 Coupe 2.2 HDI
Re: Oil Temp Gauge
Hi, the oil gauge temp probe is the connector you can see at the bottom front of the engine - probably covered in gunk.
Try this connector first, if not maybe PP2000 needs to configure the gauge but I'm sure the coupe has a 5 dial dash as standard.
RobMorris
Re: Oil Temp Gauge
Post by RobMorris »
Thanks - I will firstly check / clean gunk and revert!
