cooling fan malfunction
Plz my 2003 peugeot 406 cooling fan don't work after iginetion off causing engine overheat, once the iginetion turned on the fan start to work normally, and temp. Return to normal, how can i fix this problem?!!! i have checked fan relays and all of them work normally... Also there is afault saved in car p0485
Re: cooling fan malfunction
Fixed
it was slow fan resistor
Nice simple fix?
