Hi everyone,
So I replaced the battery in the remote key (99p - thanks eBay!). The light came on constantly for about five minutes then went off. The big button doesn't do anything. The little one's rubber has partly disappeared into the housing. I tried reversing the polarity just in case. I took the battery out and tried again and the light didn't do anything at all.
Is the key bust? (possibly I put the final nail in the coffin by reversing the polarity?) Or, worse, could the car's system be duff?
Any and all help very gratefully received.
Regards
Hugh
Remote central locking
T9 406 1.8 petrol (borrowing my Dad's)
Re: Remote central locking
Putting the battery in arse-about-face shouldn't hurt anything, it just won't operate.
Sounds like the remote's button is permanently engaged to me. You should be able to source a new remote?? and change over the circuit board and security chip from your old unit.
Im sure you need to resync the key after taking the battery. Cant remember the procedure but someone on here will know
Thanks very much guys - might be a bit simpler than I thought looks like then. Why do I always assume the worst??
Because Peugeot.hugh wrote:Why do I always assume the worst??
(I tried reversing the polarity just in case)hugh wrote:Hi everyone,
Regards
Hugh
The battery might now be fubard,
'Sometimes Cheap batterys dont have much power in them when you get them they come from china.
Grab a Varta one from asda /tesco or something.,
