anyone help me out with pp2000
gavintwopies
Post by gavintwopies »
Looking to see who could temporarily help me out with some pp2000 love??
just need abs system checking out to let me know whats at fault as ive already fitted 2x abs rings thinking it was that but the error message is still there
cheers in adavance
trem1
Re: anyone help me out with pp2000
Post by trem1 »
Might help if we knew your location
gavintwopies
thought it would of displayed automatically ........... oh well its Washington tyne and wear.
gavintwopies
cheers for the reply ive just updated it.
Main reason for the rush is i bought the car on the proviso that all it required was a wheel bearing , granted the body works a bit rough but for 200 quid you cant expect miracles.
Then mot is due middle of this month (17th) and its now out of tax too, so i cant really road test the car as i need to invest in tax to long distance test it but almost all knocks and bangs have been removed so just want to see what the last fixes would be to remove the "abs fault" & "braking fault" off the console screen as it could be an mot failure with it dispayed??
I'm not 100% sure, but if the ABS fault comes up before you drive anywhere this points to a sensor, but if you start to drive and then you get the fault message this may point to a reluctor ring..??
It makes sense to me... :idea:
gavintwopies
Well this thing had two missing abs rings on the front so had to fit them myself, after which the abs sensors seem to get a variable resistance once the wheel was rotated and using a multi meter, however I can't find the entry point into the cabin for the rear abs plugs so I can check them without using pp2000, but that said pp2000 would let me see what the abs ecu thinks is at fault allowing me to stop wasting my time guessing.
