So I just filled up my V6 with petrol at a Shell filling station and it reads on empty. Maybe a fuel sender but it is only ever since my cluster problem a couple of days ago! Right now everything is normal, the fuel gauge is the only thing.
Sent from my iPhone 6 using Tapatalk
Just filled up but still on empty!
- peugeot30v6
- peugeot30v6
Re: Just filled up but still on empty!
It reads km because I bought the car in France[emoji632]
A bit beside the point I know, but some years ago I filled up at the Shell at Sterling Corner. As I intended filling completely, I didn't bother looking at the pump, but just waited for delivery to stop. After what I though was an inordinate amount of time, I checked the pump which said I had put 125 litres in. As it was only supposed to be a 60 litre tank I thought I would check the gauge. It read the same 1/4 tank as when I had pulled in. Neither myself or any of the guys there could explain that one, so I drove to S Mimms Services at M25 J23 and filled there. 40+ litres went in and the gauge read full.
1998 2.1 GLX TD
Not much help but my fuel gauge did something similar at one point after the battery was a little flat and cranking the car caused everything to pulse, putting some fuel in didn't fix it for me either, though it did eventually start to read correctly again. (or as correct as 406 gauges get anyway).
Had a slightly similar thing happen to mine recently.
I took the car over to Holland and on the day of my return went to the filling station to put some fuel in. Not a fill up, I hasten to add, just about 20 Euros or so. The gauge didn't register this and the mfd 'miles remaining' figure didn't increase either.
It stayed like this all the way back to the ferry and only when I drove off the ferry at Harwich down a fairly sharp incline did I notice the 'missing' fuel re-appear on the gauge!
I guess the float in the tank got stuck or something.....
i too used to have this issue the car gauge would read all the way down to zero then the red light would come on if you let it go this low you had to put more than 4 gallon (£25) in to get the gauge to read the correct value otherwise it would show nothing at all.
try and keep it so that the red light does not come on and it should function as intended.
"It reads km because I bought the car in France"
You can change this on the clock setting
Look at the O.P first post the speedo is in KPH, you can't change THAT in your settings
2002 110 HDi estate, Rapier in monaco blue! ( found quite a bit more power ) SOLD I've sorted the airbag light
2006 206 1.4 16v sport in Aegean blue ( wife's shopping trolley )
2006 BMW e61 535d m-sport run's for cover
