Intermittent auto wipers
peugeot30v6
Post by peugeot30v6 »
When I turn my auto wipers on, everytime I turn the ignition back on I have to turn them off and on again. Maybe a problem with the stalk or something but they wont stay on when the ignition it turned off. What could it be?
Re: Intermittent auto wipers
They're supposed to do that. Saves them trying to operate if they're frozen solid to the screen, for example.
MixMan
Post by MixMan »
That is quite correct. Turning the ignition off interupts the sensor from the actuator and needs to be reset each time.
Currently frustrated by: 2002 2.2HDi Executive Saloon
peugeot30v6
Its pretty annoying. The auto wipers are a bit of a hit and miss, they only come on if it is pouring down . I dont really notice if there on or not[emoji1]
In Peugeot Planet they've got something like 5 sensitivity settings. Or is it 3? Anyway, they can be adjusted. Mine work ok but I preferred the ones on my D8.
There are 3 settings in Planet - of which seem to make no difference at all to how they work... ( don't select the timed rear wiper in relation to blah blah.. option - the wipers go tits up.. )
Mine sweep okay in light rain, and go faster when the rain gets heavier so I guess they work fine.
If its a big problem, you can disconnect the sensor behind the rear view mirror and the wipers go back to normal ' delay ' wipers - but doing this means you lose your auto-headlight feature.. :roll:
peugeot30v6
I like the auto headlights. I guess I will just have to live with it.
They are 'adaptive', if you let them operate on auto for a time they normally adjust reasonably well to suit the amount of water hitting the screen.
I like the way they wipe the screen immediately when deluged with spray from a passing truck. :cheesy:
Doggy wrote: I like the way they wipe the screen immediately when deluged with spray from a passing truck. :cheesy:
I used to love that, the wipers would react before you thought to. The Volvo ones are shyte, you adjust the 'sensitivity' on the stalk :? why do you need that? it doesn't help one bit. I thought the Peugeot ones worked perfectly in comparison.
trufflehunt
Post by trufflehunt »
I think the 406 wipers are great.
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
Rolebama
Post by Rolebama »
I too think they are great. I have noticed that when hitting the spray from a lorry I am overtaking in heavy rain, they seem to go faster than if I turn them onto high speed, but that could just be my imagination. I have always hated standard intermittents because they always seem to be either too often with consequent squealing from dry screen, or too slow and I end up using the flick wipe anyway.
1998 2.1 GLX TD
