blower
paul61
blower
Post by paul61 »
my blower just gave up !
checked fuse layout in owners manual - only found 2 possibles - F2 in pass comp.- 5 amp
& number 18 in engine comp. a 40 amp - neither are blown - checking in Haynes, am I looking at replacing blower motor / blower motor control module or any other (pref. easier) :?: things I've missed ?
jonsowman
Re: blower
Post by jonsowman »
The blower control module can certainly fail in this manner. Have a search for "6441L2"
Re: blower
Quick check, with engine running and blower set to full speed, reach behind the passenger side carpet under the glovebox and look for some thick wires going into a green connector. Not easy to see as its tucked away a bit. Give these wires/connectors a wiggle and see if the fan comes to life.
If so then an eBay search for the above :arrowu: will get you a replacement for around £25, its held in by a 6mm bolt.
If no joy then there is a possibility you have a fault with the ignition barrel, which is less common but not unheard of.
Puggy2
Re: blower
Post by Puggy2 »
Or it could be the motor very easy to remove & test, under left hand side can be easier to remove glove box just 2 white plastic pins.
paul61
Re: blower
Post by paul61 »
if it's ignition barrel- does that mean new ECU ?
gumby6371
Re: blower
Post by gumby6371 »
Usually poor or loose connections but have a play with the blower first.
I have a working D8 complete blower if you're near TF3 but won't fit a D9. Post your model in your SIG as it helps for future advice.
5 minute job to remove a blower motor on these so don't worry about it being a big job.
markw
Re: blower
Post by markw »
paul61 wrote:if it's ignition barrel- does that mean new ECU ?
No. You can just replace the switch block on the back of it so you retain the use of your original keys.
