unknown pp2000 engine ecu warning
hi friends
just got my new pp2000 up and running which i love!
on global check, i get a warning that the engine ecu is nouvelle 406 bosch mp 5.2
but no fault codes
is this the engine ecu it should have or has it been replace with different?
i have a year 2000 406 2.0 litre petrol RFV
build code 83838
but no fault codes
build code 83838
Gray
2000 D9 2.0 litre RFV saloon
Re: unknown pp2000 engine ecu warning
Hmm, Service Box isn't telling me which Bosch ecu yours is meant to have, all I get is the part number with no way of cross-referencing it. No RFV in the D9 Haynes? Strange. D8 says Bosch MP5.1.1 or MP5.2
Just a thought, are you selecting 406 Neuvelle when you're going into PP?
Your RPO/build code is 8383, I can't remember if you need to put the final 89 in there, that's the factory code anyway.
Sorry yes its bosch mp 5.2
Yes i am putting in 406 r which is restyle= neuvelle.
Sent from my iPhone using Tapatalk
Gray
But why is it saying warning on the main screen but then when you enter the ecu there is no faults and no other screen that you see this warning again
Gray
Maybe it's saying "watch out - it's an MP5.2 not a 5.1.1."
Need your help friends
Had a better chance to look at pp2000 today.
As my car is an RFV motor is this the correct ecu?
Becuase there is a RFV bosch 5.2 and a R6E bosch 5.2 option on pp2000
This could be why the warning
Let me know what can be done!
i think this could be why my fuel economy is bad and can smell raw fuel
Gray
Anyone?
Gray
Has the ecu been unlocked. Apparently they can be unlocked so they don't need any code, or unlocked so that you enter your own code. I have been told that this 'could' put up an error. Maybe a past owner did this?
1998 2.1 GLX TD
that could be the case but i dont know.Rolebama wrote:Has the ecu been unlocked. Apparently they can be unlocked so they don't need any code, or unlocked so that you enter your own code. I have been told that this 'could' put up an error. Maybe a past owner did this?
searching the internet it seems that the ecu is correct as there was 2 options of ecu, but im not certain.
im only alarmed because its giving me a warning
Gray
can anyone shed some lite on this
thanks
thanks
Gray
