Hi all
My central locking occasionally wont lock and I have to walk around the car and re-slam the doors until it does.
Does anyone have any ideas?
I'm kinda hoping that something just needs a squirt somewhere.
Cheers
Ben
Central locking playing up
- jameslxdt
is this using the remote or the key?
- jameslxdt
try replacing the batteries in the remote
- jameslxdt
if its unlocking straight away it could be the microswitches that control the interior light getting stuck,
does the dead locking work?
Aye, it does sound like a switch problem, might even get away with buying an aerosol can of electrical contact cleaner from Maplins and squirting round each door's 'button' then working the button for a minute or so.jameslxdt wrote:if its unlocking straight away it could be the microswitches that control the interior light getting stuck,
However I'm not sure it would be the interior light switches - they can stay off when the door is just slightly open. When I first changed a dashboard light on my 406 I bought a few extra bulbs and parked them in the unused holes for safe keeping. One of those holes was for a 'door open' light, and whadda ya know when I put the bulb in it started working! I've noticed that this light however seems to use a different way to sense open doors as the light will show a good while before the interior lights will come on!
Since the detection on the central locking is a lot more sensitive to open doors than the interior lights I'd suggest that there's another button/switch/sensor in each door which is the culprit in this case.
