Imobby question
Sonia406
Imobby question
Post by Sonia406 »
Right so this new car has many fan-dangled stuff going on inside of it...
Getting to grips with most of it, though had to be shown about the memory seats yesterday :oops:
Anywayyyyy... on the A pillars is the alarm sensor what nots. I know the button in the middle should disable the motion sensor.
Question is: Should that button stay down as far as the heated seats button? (Mine doesn't stay down)
How do I know if the motion sensor is activated or deactivated? Or is that a practical test :evil:
Miss Pug 2001 - 2023.
jasper5
Re: Imobby question
Post by jasper5 »
When you press the motion sensor button a yellow light should light up in the switch.This is the one you use when you have the dog in the car, right?
jonsowman
Re: Imobby question
Post by jonsowman »
That switch doesn't stay depressed like the heated seats. Springs back up to normal height. I.e., what you describe is normal 8)
Re: Imobby question
I think you have to lock the car within a short period of pressing the button for the ultrasonic motion sensors to stay disabled. I'm never sure, so lock the car with the door lock, (which completely disables the alarm), if I ever leave the dogs in there.
Having forgotten one or twice, I'm now fairly sure the motion sensors don't "reach" as far as the boot.
markw
Re: Imobby question
Post by markw »
On my D9 Coupe, you have to depress the button within a few seconds of switching off and withdrawing the key otherwise the press doesn't get recognised.
The red led will show solid, not flashing , as it does when the alarm is armed, to indicate that the ultrasonics have been disabled.
Re: Imobby question
If memory serves you need to hold it down for 4 seconds? Also, in my cars I'm pretty certain the alarm didn't arm unless you deadlocked
markw
Re: Imobby question
Post by markw »
Yes that's right. Just locking without deadlock leaves the alarm disabled.
Never come across the 4 second thing, but I do know that the press has to be within a certain time window or it gets ignored.....
Re: Imobby question
Every reply has a different answer! I never did work out how to use that button....
Re: Imobby question
Another thought - at Prescott, we proved pressing the lock button on the r/c put the deadlocks on, (later full mux cars at least), pressing it a second time removed the deadlocks, but leaves it locked. Maybe this disables the sensors or even the alarm.
Guess it needs testing.......
Sonia406
Re: Imobby question
Post by Sonia406 »
Doggy wrote:Another thought - at Prescott, we proved pressing the lock button on the r/c put the deadlocks on, (later full mux cars at least), pressing it a second time removed the deadlocks, but leaves it locked. Maybe this disables the sensors or even the alarm.
Ok... I will get Dave to try this out later for me.... :shock: :evil:
Re: Imobby question
If you put your drivers window down, you can test it.
One press deadlocks the doors and sets the alarm ( try opening your door from inside, through window, it won't open)
Two presses in quick succession releases the deadlocks ( after first locking them :roll: ) so you can open the car from inside and I think the alarm is also deactivated?
To test your alarm, press the lock button on your fob with one door open. If you close the door then open it again the alarm sounds iirc.
Sonia406
Re: Imobby question
Post by Sonia406 »
I can't lock the car with a door slightly open, it sounds one beep and tells me to sort myself out :lol:
Yesterday I did pull the drivers window down and locked it and waved an arm in to try the sensors and on both locks it didn't sense movement and go off... (Unless there's a set period after it's locked it then looks for movement?)
I forgot to try the door handle :oops: to test the dead-locking of it all :lol:
Someone mentioned a red flashing light to warn the alarm is armed etc - where is this light usually? :oops:
Anyone elses drivers wing mirror go absolutely berserk when the car is unlocked? :evil:
Re: Imobby question
My drivers mirror goes mental when I turn ignition on, it first goes out to point at the sky and just whirrs away for 10 seconds or so, I can't move the mirror until it stops and sorts itself out....
Sonia406
Re: Imobby question
Post by Sonia406 »
GingerMagic wrote:My drivers mirror goes mental when I turn ignition on, it first goes out to point at the sky and just whirrs away for 10 seconds or so, I can't move the mirror until it stops and sorts itself out....
Yep..... mines the same! :lol:
Puggy2
Re: Imobby question
Post by Puggy2 »
My passenger the same but if I touch a seat memory button it goes to a half decent position
