my battery is being drained.
pugnut
Post by pugnut »
Hi all
I have been plagued with a constantly dying battery this weekend, I will get the battery checked out, no problem, but if it is in fact ok, anyone got any ideas as to how to fault find if its a short? tried putting an ammeter individually across all the fuse contacts but there are about 60,000 fuses to check (oh alright I lied, theres only about 25) I started - but ran out of time . C'est la vie. Thing is, it's happening with the key out and the car locked - would I be right in thinking the only live circuit in this case is the central locking and the alarm? The alarm fuse contacts give me ZERO amps load - as do all the others I've tried so far :(, except the interior light circuit with the key in the ignition - I get 0.1A showing, which (having been the victim in the past of little fingers fiddling) wasnt enough to drain the battery overnight. I dont wanna do the 'disconnect the battery overnight' trick as last time I did this the keys had to be recoded - not going down that road again!
Clutching at straws - I can see this running into a big auto electricians bill but just in case, thought I'd ask here, Thanks in advance
Cheers
Rob
406 Exec 2.0 HDi 110
Re: my battery is being drained.
Hi, what is the behavior of the car as it starts, is it a sluggish starter with dim dash lights or are the dash lights okay? No matter how flat my battery went the electric seats were the last to die.... :wink:
I thought my battery was dying a few months back but turns out my starter was slowly seizing up :roll:
I can't think of anything that would drain the battery too much as the ' power saving mode ' would pop up? Is it maybe lots of door opening but not starting the engine?
I too and fumbling for drinking tubes.....
See what the battery checks out at first before you go grabbing dried wheat stalks:wink:
Does it have an after-market stereo, phone kit, anything like that?
If it's in a bad way, your battery will probably self-discharge when disconnected, (taking precautions to disconnect correctly, of course).
pugnut
Post by pugnut »
Ohhh sh** a month has almost passed - has it been that long? Apologies for not getting back to you. Problem is solved and this is how I traced the fault:
At work we have one of these:
http://www.tool-net.co.uk/p-333053/clar ... tAod4XYA5g
And I was allowed to leave it connected to my battery during the day, the theory being if THAT drained after eight hours at work, I can eliminate the battery as being the cause.
It didn't. Car started with consummate ease on completion of my shift.
Ergo, my battery had in fact died!
£58.99 bought me a new one from http://thebatteryshop.co.uk/ and my starting woes vanished overnight.
I was convinced it couldn't be the battery. Wrong again. As usual. :-/
Good news and the right time of year to get it sorted before the cold weather arrives.
Ah, nicely done :cheesy: It just goes to show, always start from the basics and never assume anything...
Good result and , as Doggy says, a fresh battery for the oncoming winter ' battery bashing ' season... :cheesy:
