i have the airbag light on. checked connectors look good. Any other options i can take?
Can you just disconnect airbag ecu?
just want to get mot sorted..
airbag light
airbag light
2002 406 2.2 hdi glx estate
staffs
staffs
Re: airbag light
No unfortunately not, vosa have tightened up the mot regsbillybob69 wrote:i have the airbag light on. checked connectors look good. Any other options i can take?
So the airbag light has to light up and go out so disconnecting the ECU won't do you any good.
Have you checked the wiring/connectors on the seat belt pretensioners
Re: airbag light
Hi mate, lots of threads on here regarding this one, usually the orange wire from passenger seatbelt to airbag connections under the seat.
Try disconnecting repeatedly, check the one behind the connectors too.
