hi all
my brother in law's moms 406 won't start
the battery went flat completely she tried to charge the battery but it would not charge up enough to start it
i went to have a look it and it is coming up with antitheft system defective
it was ok till the battery went flat but it just keeps coming up with the above about 15 seconds after the key is turned on
anyone got any ideas
2001 hdi won't start
- 1.6 8v
Re: 2001 hdi won't start
squirrell25 wrote:hi all
Personally, I don't have a clue - I am sure one of the boys will answer soon.
If you tried to charge on the car may have disturbed the bsi, other than that I can't give you any help................
BOYSSSSSSSSSSSSSSSSSsss
Miss Pug 2001 - 2023.
Why did the battery go flat, is it kernackered? Did it get a new battery?
- 1.6 8v
steve_earwig wrote:Why did the battery go flat, is it kernackered? Did it get a new battery?
battery went flat when we had the snow and it was'nt used for about a week as she won't drive in snow
i assume it was on it's way out as she said in the cold weather it was turning over slower
she has put a new battery on it but it is still same message on the sreen
Try a bsi reset.. there is a guide somewhere on here,
Might not work but its worth the waste of 5 mins or so.
