Hi guyz and gals
Sittin' Here with a, to me, weird problem on my 2002 d9 406 hdi:
Occationaly the power to the cabin heater blower dissapears. When it does, the bsi makes a almost not hearable beeping Sound.
Has anyone experienced That before?
Best Regards
Jakob
Strange power to heater blower issue
BR
Jakob
2002 406 2,0 HDi aut. Estate - Daily Driver. Now on 518000 KMs W/same engine/Gearbox :-)
1993 Yamaha XT600e 3UW - the ongoing project...It NEVER ends MUAAAHAHAHAHA
Jakob
Re: Strange power to heater blower issue
next time it does it try wiggling the key in the ignition switch
to see if it comes back on , if it does ign barrel could be on its
way out this is only one of several possibilities .
Hi, most common problem is either the ignition barrel, or the module behind centre console.
When engine is running, put blower on full speed and then lean under the passenger side and reach under the dashboard for some thick wires - give them a wiggle and if the blower suddenly works then its probably the module.
£25 from eBay and a 5 minute fix.
Hi again
Did some diagnostic this afternoon. Definately the resistor as the blower stoppes and started everytime I wiggled the wires at the resistor connectors
BR
Jakob
BR
Jakob
BR
Jakob
Jakob
Hi Jakob, try this.
http://www.ebay.co.uk/itm/Citreon-C2-C3 ... 4abed1e620
This is held on by a 8mm ( i think ) bolt, can be accessed by following the wires down from under the glovebox to behind the centre console.
Kelv.
Kelv.
