B.S.I. WHERE IS IT ?
- neildavies
- jameslxdt
as there is no led on the key, the 206 is full CAN which is why the code reader works on it and not the coupe, the coupe is obd1 and the 206 is obd2 even though there from the same year
- neildavies
Hi James, Just to add though, the coupe doesn't have a red led on the keyfob either, they're exactly the same keys. Could it still be obd1 though?
Glad to finally speak to someone with knowledge of this, cheers james.
2007 307cc Sport 2.0 HDi 136
- jameslxdt
the only way to tell if a 206 is full CAN or not is between the key, on the 406 there's no way to tell, as it was never full CAN, the 406 only got a bsi at the most, which makes all 406's obd1
- neildavies
- jameslxdt
i would sincereley doubt it, all 406's petrol or diesel were obd1 unfortunatley
- jameslxdt
say what?
206's up to mid 2002 were semi-can
after that they were full mux/full can
petrol 406's from 2002 onwards are OBD2 and diesel 406's are OBD2 from 2004 onwards
- DaiRees
Hi folks, I'm sitting here with Mr Davies who has kindly brought his code reader down, and the good news is it works on my Jan '02 carjameslxdt wrote: petrol 406's from 2002 onwards are OBD2 and diesel 406's are OBD2 from 2004 onwards
Got 2 codes for you to help me with James but I'll start a new fred!
lil different up to 2002 the 206 was semi-mux after that it was full mux based on CAN for the main systems and VAN for the secondary system. so not full CANjameslxdt wrote:say what?
