what is the sequence to enter the code for the radio in a pug 406 ?
welton mine is the same as yours single slot cd player, just curious in case i ever need to know, it does not play properly anyway i am so tempted to get it replaced, will not even play a copied music cd
radio code how to enter
when it reads CODE press button number 1, then use next track/radio station seek button (small arrow pointing right), until you have first number in code, then press number 1 again to move to next number, and repeat process,when code is entered in full press number 1 and will let you use the radio.
if you put code in wrong you will hear a beep and have to wait 1 minute until you can try again, but be carefull cos every time u get it wrong the waiting time doubles...2mins.....4mins.....8 mins... all the way up to 32mins wait!!
if you dont do it, it wont get broke!!
