Hopefully someone can help me with my window regulator, which won't work. I've just spent the last hour trying to find the fault using a multimeter.The main drivers door window switch, only works for the passenger window only, everything great there. I've checked the one touch auto switch, and power is only going to one pin on the switch, and also one pin on the plug connector (PIN 6) which fits into the regulator.
I figured maybe 2 or 3 pins need power to work correctly.
I've checked the Fuses in engine bay and fuses under immobiliser keypad, everything ok there.
Stripped door card and foam, and removed black tape from wiring, and no breaks in wiring.
I've even removed the black rubber sleeve which fits between the car body and door, and no wiring breaks or splits there.
I wonder if the connector plug behind the rubber sleeve could be accessed safely, but without having to remove the door, or parts of the dashboard.
Anybody else had a similar problem as this, and if so was it easy to repair without having to go to an auto-electrician !.
My car is a 1996 406 L DT (D8-I think).
Thanks for anyone offering help with this problem.
Cheers
Phil.
