Engine Immobiliser Fault
Re: Engine Immobiliser Fault
Good work indeed..!
Check the bottom of the door to see if the drain holes are clear - then check the door seal itself. Mine looked fine on my O/S/R door but water was pouring in. Donor cars door seal is now fitted and has sorted it....
Great news! :cheesy:
Blocked sunroof drains, (if fitted), are another common cause of water ingress.
reconoistre
Post by reconoistre »
now I have abs light problem replced sensor fitted new rear hub still the light comes on where to now?
Possibly another casualty of the corroded connectors?
Also, the ABS units do go wrong, it's not common but...
exec406
Post by exec406 »
I had an intermittent start/non start issue.
Couldn't be traced for a while and then eventually it was traced to the high pressure fuel pump not generating the required 300bar.
Starts fine now and the acceleration seems better.
PeterN
Post by PeterN »
I had this problem and the first thing that happened was that the instruments went haywire. I thought the fuel sensor was faulty as when I cornered it went from full to empty but it was actually caused by half an inch of water slopping about under the carpet.
