Hi!
We have a 1999 406 RHY. I replaced doors from a 2002 RHZ and the central lock is not working properly.
the front lock motor connector in the front doors is not the same. Everything else works perfectly!
The old 5 wire
the new 6-wire
How can I solve how the lock works?
(Sorry for my english...I'm from Hungary)
Replaced doors / Central locking problem
- Attachments
- (1.9 MiB) Not downloaded yet
- (1.43 MiB) Not downloaded yet
- (1.86 MiB) Not downloaded yet
Re: Replaced doors / Central locking problem
Is it not possible to use the old lock motor in the new door?
It's a bit tricky but I'm sure you could put the old wiring loom into the new door?
1999 T4 family wagon
2005 Vauxhall Meriva
In my opinion, this would be your only option. The 2 cars would have different bsi's (which controls the central locking). Yours would be an early version, the donor the later version. My experience with these cars tells me that, unless you can find decent detailed wiring diagrams for either system, it is unlikely you will get it to work. Don't just try to make them work as you run the chance of damaging the bsi. Just put the wiring looms and central locking units from your old doors into the new doors.GingerMagic wrote: ↑Sun Apr 04, 2021 9:26 am It's a bit tricky but I'm sure you could put the old wiring loom into the new door?
Serial 406hdi licker
