406 2.0 hdi TPS
JohnRoss
406 2.0 hdi TPS
Post by JohnRoss »
I need to change my TPS - Throttle Positioning Sensor.
On Amazon there are a few that look identical although there seem to be a few slight variations in numbering.
I have found:
Throttle Position Sensor 15980-67G00 / 1920.9W
Here is the link
https://www.amazon.co.uk/Throttle-Posit ... =8-1-fkmr0
They say it is ok for 406. I think my one is a 1920X1 whereas this is 1920.9W
They look identical but are these slight number differences critical?
Any expert advice much appreciated.
Many thanks
John
Limassol, Cyprus
frog
Re: 406 2.0 hdi TPS
Post by frog »
JohnRoss wrote: Thu Nov 14, 2019 11:21 am They look identical but are these slight number differences critical?
The 1920.9W seems for the petrol models, while the 1920X1 is for diesel.
I would advise sticking to the 1920X1 for your HDI.
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
frog
Re: 406 2.0 hdi TPS
Post by frog »
frog wrote: Thu Nov 14, 2019 2:28 pm The 1920.9W seems for the petrol models, while the 1920X1 is for diesel.
Maybe not, looks like both are indeed the same: both OEM numbers are listed at the part shown here: https://www.ebay.co.uk/p/Sensor-Throttl ... 3017021256 .
Current "fleet":
Previously owned:
Re: 406 2.0 hdi TPS
It's also possible to clean the springs from inside the TPS rather than buy a new one.
Not always a fix but for the sake of 10 mins....
rwb
Re: 406 2.0 hdi TPS
Post by rwb »
My HDi 90 used to eat TPSs.
Eventually I had a cycle of two of them: one on the car and one being cleaned out.
The ones that came off felt gritty -- I expect due to their location in the engine bay.
Here's what I found: viewtopic.php?f=1&t=19303&p=191878
You can expect parts with different XXXX.YY numbers to be mutually incompatible.
The actual part number is a long number that begins with a 9 and is usually on a sticker on the part. There can be many of these for the same XXXX.YY and I don't know how interchangeable they are.
frog
Re: 406 2.0 hdi TPS
Post by frog »
rwb wrote: Thu Nov 14, 2019 7:41 pm My HDi 90 used to eat TPSs.
I've never had to replace mine. I do spray it with electric contact cleaner spray regularly (~ every 2 years).
Cheapest one I could find in a 30 second search: € 13,77 incl. shipping - for 406 2.0 HDi & 2.2 HDi.
Current "fleet":
Previously owned:
