Mot headlight fail headache
Greetings pug fans.
My 406 failed on headlights t'other week - (n/s beam too low) and I'm getting bloody nowhere with it, so... in the event that others may have acquired the wisdom I lack, I very gratefully seek any help, advice, assistance, insults or whatever you feel.
So you have three 10mm bolts fixing the headlamp to the body, one on top one below the bulkhead, number three a reet bar steward to remove tucked waaaaaay in there bolted to the wing. They have big enough holes to adjust a fair way left right up down forward and back. And then you have the two 6mm adjusters up/down on the motor unit and left/right twixt indicator and high beam. Oh plus the big fat windey up and down plastic nut on the bottom lug. I have tried every possible combination of adjustment that it is possible to try, the drivers side has been adjusted down to its lower limit, the near side to its upper but still too low. Had both of the electric motors out, checked function fwd and reverse all fine and yet... no friggin' joy. Five minute job I thought. Wotcha reckon? I could replace the light unit but that would be a waste of money if the beam is still too low. Borrowed the kids mums 3008 and shined hers against a wall about 25 feet away then mine. The right hand beam was spot on from what I could make out. Studiously applied lump hammer to the bulkhead perhaps? Buggered if I know. As I have said, grateful thanks in advance .
406 Exec 2.0 HDi 110
Re: Mot headlight fail headache
Is the bulb in upside down? Or not in squarely?
Don't laugh, it's a common mistake and makes the beam go haywire....
I once managed to shove the hood/shield that fits over the dip bulb off to one side & it deflected the beam miles off line.
Have a careful look through the glass and try to spot any differences in how the bulb sits within the shield on your 'good' and 'bad' sides.
As GM says it's easy to get the lamp sitting incorrectly within the holder. It should have one of the 3 tabs top dead centre with the 2 connection spades horizontal. Again, comparing one side with the other should help.
Bear in mind that if you do get the lamp seated correctly / shield sitting right, you may have inadvertently adjusted the beam a long way from where it should be.
Right. Took the offending headlight out and on a hunch dremmelled what appeared to be a lumpy bit a wee tiny tad. Although this pushes the bulb UP it sends the beam FURTHER DOWN
Light bulb moment (excuse the pun
): the reflector is a MIRROR you DUMMY, it INVERTS the image!!! Local breakers luckily had one, I was getting desperate, bought it, tried it, adjusted it and taking it for retest tomorrow. Many many thanks chaps.
Rob
Rob
How long have you had the car? just thinking it might've had a slight biff on the nose at some point...
Might check all these to see if it cures my awful beam pattern... Did any of the above fix your issue? My reflector is very loose too, when I changed the sidelight bulb it was moving all over the place when I fiddled it back in...
If its an estate do you know there is a headlight height adjuster under the dashboard by the steering wheel, it adjusts both sides of course but useful to remember.
Yep, been playing with that to check the adjusters work, they do. What I have done is find that the passenger headlight is a tiny bit loose. Now fixed with a scrap bit of tree I found on the road, wedged under the headlight. The few mm it lifted it has made the light throw much better, and a test drive home just now with the headlight adjustment on 0 resulted in no flashing of lights from oncoming traffic.
To my eye the light bulb itself seems to be at a bit of a downward angle too, will have a look at that but the battery box or headlight needs to Come out, or I need to teach my 6 year old how to remove and refit a bulb!
It's probably a 6 year old that put the bulb in.....
It's possible to do without removing anything, just a little awkward.
Sounds like a much easier job pottering away at it with lots of access though! Although now the beam is much improved the handbrake needs attention first!
