snapped wiring near fan on 206 Hdi
Davie206
Post by Davie206 »
Found this while looking through the grille today, can't see where it is meant to go but I'm guessing it has something to do with the fan. It is 2 black wires in a black sleeve.
Re: snapped wiring near fan on 206 Hdi
Can you read any codes off of the wires?
Davie206
Post by Davie206 »
Can't see any codes on the wires
I'm guessing either bonnet catch alarm, or front fogs...or as OP says, fan relay.
If you peel back the sheath you should see some numbers on the wires - this will tell you what they are meant to connect to.
