Dismantle blower motor
Hi everyone. I need to get my blower motor apart. The connector on it has started to melt and the terminal is now loose and I'd like to secure it if I can. So, could anyone tell me how to get my heater blower motor apart. I know you can change the brushes so there must be a way to do it. There is three indents with rubber stoppers in there. Do you push these in and up or down, do you need to do all three together which with only two hands isn't easy and doing one at a time isn't working either.
It may only be 12V but it's the amphere that kills you!
3Ltr V6 ES9J4S D8
3Ltr V6 ES9J4S D8
- Bailes1992
Re: Dismantle blower motor
Remove the glovebox/lower part of the dash and there is 4/5 screws on the bottom of the blower unit and the blower just drops out ![Smile :)](./images/smilies/icon_smile.gif)
![Image](http://i52.photobucket.com/albums/g16/Bailes1992/Default%202/DSC00010-1.jpg)
And in regards to your sig... It may be the amps that kill you, but 12v will never be able to push another current through to kill you anyway ;)
Three screws to get the motor out, but how do you get into the motor. It only takes 0.3Amp to kill you but I never said 12V was enough to push it through!
3Ltr V6 ES9J4S D8
3Ltr V6 ES9J4S D8
- Bailes1992
Just take the glovebox/lower half of the dash out and theres 3 screws on the bottom of it and the unit simply drops out like the picture above!lecky4 wrote:Three screws to get the motor out, but how do you get into the motor. It only takes 0.3Amp to kill you but I never said 12V was enough to push it through!
65miliamp to kill you ;) thats 0.065 amp
It's not that I'm ungrateful for the help or trying to be awkward, but the motor is out and in my garage. As stated in the original post I need to take it apart.
3Ltr V6 ES9J4S D8
3Ltr V6 ES9J4S D8
- Bailes1992
Ohh I thought you meant remove it from the carlecky4 wrote:It's not that I'm ungrateful for the help or trying to be awkward, but the motor is out and in my garage. As stated in the original post I need to take it apart.
![Laughing :lol:](./images/smilies/icon_lol.gif)
just get a new one from the scrappyard its a lot eaiser,because even if you get it apart where you going to get the parts from?
but i suppose you have nothing to loose so go for it as i dont think anyone has stripped one.
ok. which connector started to melt ? picture please ...
Sorry no pictures as where it's difficult to get one worth posting. It's the connector that's actually on the motor. There must be a way in because you can buy the brushes to replace them.
3Ltr V6 ES9J4S D8
3Ltr V6 ES9J4S D8
It's possible to get it out. You've already seen the 3 rubber stoppers. Take a flat blade screwdriver, insert into one of the holes, pivot the screwdriver away from the centre of the blower so that the screwdriver's flat end pushes the rubber inwards towards the centre of the blower and upwards. Work your way around all 3 holes so that the motor comes upwards bit by bit.
Hope you can understand my description.![Smile :)](./images/smilies/icon_smile.gif)
gwinter, your a god send. Exactly the info I needed. At least now I can use the motor of the incorrect fan I bought. ![Cheesy Grin :cheesy:](./images/smilies/icon_cheesygrin.gif)
3Ltr V6 ES9J4S D8
3Ltr V6 ES9J4S D8
Ahh cunning! I was wondering what you'd be able to do with a dismantled fanlecky4 wrote:At least now I can use the motor of the incorrect fan I bought.
BTW, is your sig right? An ES9J4S in a D8?!? If so, how did you get the D9 ECU to play ball with the rest of the car (in particular the lack of a BSI), or did you just leave the D8 ECU in and live without control of the VVT solenoid?
