Whats this wire for??
Hi all,
Well I was digging around trying to find where the Heater Control Module is in my passenger footwell as my fans aren’t working inside my car!!
Well I came across this loose wire .... as I’m not really an electrics guy, I was wondering if anyone could tell me where it plugs in and what it’s for??
Secondly can anyone help and tell me where the Heater Control Module is?? Dose anyone have any pics that could help??
Thanks for reading.
Matt
Thanks for reading.
Matt
Re: Whats this wire for??
Hi matt,
what 406 have you got,?
early 406 or a D9?
not familiar with that plug on the d9
thought id ask if yours is a d9 before icheck on mine
early 406 or a D9?
that might be the wire /plug that goes into the Resistor pack thing /located behind the centre console,
didnt you have problems before with this?
old thread here viewtopic.php?f=3&t=14191&p=132136#p132157
Yes mate thats me!!
I have an early D9 2000reg.
Thanks for looking ....
Can you read any of the numbers on the wires?
Sorry mate, been looking for numbers but can't find any . Whereabouts would they be??
Here's a couple of other pics ....
Many thanks for having a look.
Matt
Matt
I could easily be wrong, but that doesn't look like an original Pug connector / loom to me.....
Totally agree with you here. Peugeot/Citroen always have numbers on wires as thats how they are coded as they do not use wiring colours. Defiantly aftermarket. Actual sheaths on the wires don't look OEM, so there's another sign it could be aftermarket. The wires are too 'colourful' to be OEMdogslife wrote:I could easily be wrong, but that doesn't look like an original Pug connector / loom to me.....
Ok cool guys ..... guess it was something that one of the previous owners added!! Might be useful later on!! pmsl
Thanks for looking!!
Probably part of an old Nokia hands-free kit
MattyF see my posting on blower motor failure before you start dismantling anything.
My 406 is lhd so will have to think rhd.
Haynes indicate two motor control units.
Follow the wires from the blower motor and if it goes to the front right of the passenger footwell right at the end and above the gear shift trunking you may be lucky with a separate unit tucked away in its own housing held by a single and visible screw.
The thin control wires from the facia panel also travel in the same direction and the motor control unit green plug should also be visible.
The other motor control unit is attached to the blower motor itself which will require removal of the bm to get at. Ugh!
During my own investigation I did not come across anything that resembled the wire in your pics and if it is an addition it looks a pretty professional job to me.
