dashboard lights
Posted: Sun Jan 06, 2008 9:54 pm
by andrew1608
I have just replaced a few light on the dashboard behind the speedo & rev counter area bulbs cost 50p each and peugeot were wanting around £1.20 per bulb, however there is no way of knowing what each bulb does, there is a printed circuit boards but behind the rev counter area there are around 6 holes and only 5 bulb you take a bulb out and don't remember where to exactly to refit it becuase you then have 2 spaces left, i did this and found i put a bulb back into the wrong whole andthe light indicator did not show, but i have contacted peugeot and they hve no papers to show what each whole does, they do have an online system which can be accessed but you have a pay to use it. An the peugeot dealers computer in the parts department is useless. It would be good if there was a diagram to show what each bulb does other than light up as it makes it easier to know the location of which bulb needs to be replace.
Re: dashboard lights
Posted: Mon Jan 07, 2008 12:20 am
It's a bit late to go tooling about on service box but you're welcome to try. Otherwise, you could try shining an LED torch through the holes and see what lights up.
Posted: Mon Jan 07, 2008 2:40 pm
by Tiny Tim
I just held mine upto the light and worked out what was what. Then I realised I didnt have a clue what my model came with (ABS etc) so stuck blubs in all of them :cheesy:
Posted: Mon Jan 07, 2008 6:21 pm
by mjb
Strange thing. I've got a traction control light which comes on for a few secs after ignition, but I don't have traction control! :)
Posted: Mon Jan 07, 2008 6:34 pm
Well it''ll never go wrong then :cheesy:
Posted: Mon Jan 07, 2008 7:57 pm
by mjb
it'll never go right either but hey ;)
