406 Estate seat belts
Hi
I have recently purchased a 406 90 HDI and have just noticed that the rear seat belt seems to be jammed, ie it will not unreel and his extreemly tight accross the seat especially when I fold the seat down. Any suggestions anyone?
Phil Robinson
- DaiRees
- Site Admin
Hiya mate, the seatbelts work on a ratchet, but it sounds like yours is retained on the ratchet even when fully retracted, probably something strange happened in a previous life (I'm assuming you mean the centre belt on the rear seat). So I would try pulling the belt tight from the lower anchor point in order to try to create a little slack to feed back into the reel, to try to release the ratchet. Kind of push it into the padding of the seat to get a bit more slack, if you're successful you'll probably hear it click as it releases.
If that doesn't work james will tell you his violent solution to this problem .
If that doesn't work the ratchet is knackered, and you can't get to it without taking the seat apart
Thanks Dai
I'll try what you suggest = I've already tried kicking it and swearing at it but you know how stubborn the French can be!
Its so tight across the seat though its pulling the cusion in hard - I doubt if I can get any slack. Is it difficult to pull the seat to bits?
Otherwise I'll have to buy a new one
Phil Robinson
Good idea that bud ... i had some trouble last week with the middle belt, had to un-bolt the lower anchor point !JimH240 wrote:My belt always used to get jammed when I put the seatback upright after a fold down to carry a load. Now i always tie the belt into a knot before lowering the seatback and this stops the belt retracting fully. No more problem when seatback is returned upright.
jim
Next time i'll try your knot idea bud ...
Pete
or how about just keep a safety pin stuck in it to save faffing with a knot? I wish I knew about this problem a few months ago...
How come everyones is breaking at the same time?
Well if you want to drop the seats, you'd unclip it, pull the seatbelt out some, put 2 bits of seatbelt next to each other and pin 'em instead of knotting 'em. Then when you're done you don't need to untie a knot, just unpin it...
