Cruise control stalks
Posted: Sat Aug 26, 2017 12:03 am
by blackblade58
I'm going through the process of fitting cruise to my 90 hdi estate and I'm completing my shopping list, I have found a lower steering wheel cowl and cruise stalk for a 406 coupe, does anyone know if this will fit a hdi estate?
Re: Cruise control stalks
Posted: Sat Aug 26, 2017 8:03 pm
by GingerMagic
If your saloon is year 2000 or newer then its exactly the same stalk and cowling - however I'm not 109% sure it will work as your saloon may have a Siemens ECU which again, I'm not sure is compatible.
Hopefully someone will be along soon to clarify.
Posted: Sat Aug 26, 2017 8:43 pm
by blackblade58
Thanks Ginger, mine is a 2001 estate. I'm not sure on the ECU, I will have a look.
Posted: Tue Oct 17, 2017 12:26 pm
by Hermione
The new cruise control stalk that has been modified for autopilot does not have a white button on the end to turn cruise control on and off. Does anyone know how to turn off cruise control entirely until it is wanted?
Posted: Thu Oct 19, 2017 10:26 pm
Set it to absent in PP? Surely if you can't turn it on then it won't work anxway.
