Water leak
Posted: Thu Feb 23, 2017 2:04 pm
by straggler
I have a 96 406 saloon which is collecting water in the boot. The nearside rear of the mat gets wet in the rain. It's not coming from the boot lid as it's just the mat. After heavy rain it pools in the corner and makes the trim surround it wet. Any idea as to where to look for a leak?
Cheers.
Re: Water leak
Posted: Thu Feb 23, 2017 2:15 pm
by frog
I had the same problem. It turned out that the water was coming in via one of the the tail lights.
You might want to check the spare wheel. Mine was swimming
Re: Water leak
Posted: Thu Feb 23, 2017 2:29 pm
by straggler
That sounds like a plan. I'm abroad at the moment and don't want to start dismantling things so will check it when I get back. Stuffing newspaper under the mat in the meantime!
Re: Water leak
Posted: Thu Feb 23, 2017 2:52 pm
by straggler
Just discovered I have water in the front passenger footwell too. This has been a longstanding problem I thought I'd sorted out (thought it was a coolant leak as the coolant needed frequent topping up) but now guessing not!
Re: Water leak
Posted: Thu Feb 23, 2017 8:29 pm
by dirtydirtydiesel
Hi,
Is the rubber seal that runs along the length of the sill still there & intact,
clumsy feet can dislodge it/damage it this in turn allows road spray to get under the doors & run
down in to the footwells
,another favourite is blocked up sunroof drains (if you have one)
Re: Water leak
Posted: Thu Feb 23, 2017 9:25 pm
by straggler
dirtydirtydiesel wrote:Hi,
It happens when the car is standing for a while.
Where would I find the sunroof drains?
Re: Water leak
Posted: Thu Feb 23, 2017 10:14 pm
by dirtydirtydiesel
Search for (sunroof woes & cures with pictures).
It's well documented on here & you've been a member longer than me
Re: Water leak
Posted: Fri Feb 24, 2017 9:24 am
by straggler
I found the post. Thanks.
Any idea how I can remove the trim panels on the A pillars? The original poster says they are on clips but mine seem reluctant to move and I don't want to force them....
Re: Water leak
Posted: Fri Feb 24, 2017 1:05 pm
by GingerMagic
Quite simple, just pull some of the rubber seal away from the trim - then pull, start from the top. If you have an executive, be gentle with the sensors at the top.
There are some spring clips in he back of the trim, which locate into square holes in the pillar, these can be a bit stiff.
Re: Water leak
Posted: Sat Feb 25, 2017 9:57 am
by straggler
GingerMagic wrote:Quite simple, just pull some of the rubber seal away from the trim - then pull, start from the top. If you have an executive, be gentle with the sensors at the top.
Nice one, thanks.
I'm abroad at the moment so will wait until I'm back in the UK before fiddling with it.
