Thinking about an Aftermarket Sunroof
- peugeot30v6
I am thinking about an aftermarket sunroof being fitted by Webasto into my 406 V6 Executive, the Sunroof is the only option that was not fitted. My two other Volvos have sunroof's and i would really like to get one in my pug. What are the pitfalls into doing this?
Re: Thinking about an Aftermarket Sunroof
Leaks, wind noise, car gets hotter when parked in the sun, less headroom, more drag......
I opened the sunroof on my last exec once in 4 years to unblock the drains, haven't opened this one in the 2 years I've had it and have no intention of trying.
- peugeot30v6
My first car, a mazda 323, had a sunroof that when it used to rain i had a bucket resting on the center console. My volvo s40 has a panoramic sunroof and is great. Not sure about a aftermarket one on my 406. I have heard alot of good things about webasto sunroof's. But the plans for that are in the near future.
I thought that a Factory roof also has strengthening around the 'hole' as it were so attacking your roof with a tin opener might affect the structural rigidity? also every car I've had with a Factory roof also has a blind that pulls across under the glass - without this you'll burn your bonce, be permanently illuminated and be annoyed at streetlights flashing overhead at night time.
I'd say AVOID this.
I'd say AVOID this.
I reckon "Webasto" will mean one of those full-length plastic jobs that unhook at the front with a couple of levers and concertina up towards the back.
I miss having a sunroof, mind you I've never experienced anything other than electric factory-fitted jobs that have either been tin (Scirocco) or glass (everything else IIRC). Never had one leak, jam or fall out on my bonce.
After-market? I'd need to investigate but I'm thinking loosing structural rigidity, fitted drunk, mangled headlining, glue everywhere, leaks and rust.
Still, Webasto have been doing them since the days of the horseless carriage so they can't be that bad...
An idea of prices. http://www.bristolsunroofs.co.uk/sunroo ... lation.php Ouch.
- Rolebama
My experience of most aftermarket sunroofs is that they are OK. They are all initially fitted with a frame which replaces any structural integrity they 'may' have lost. I have seen some where the fit is 'questionable' at best and downright shoddy at worst, but I have never seen a Webasto badly fitted. I have seen seals give up though, including on Webastos allowing you to have your own mobile sauna or tropical rain-forest depending on weather and how you have heating set. As for street lights flashing overhead etc, it only takes a little time to get used to it, same as any other light hazard at night. The only other effect I can think of is that it could either increase or decrease the car's value if you decide to sell later.
1998 2.1 GLX TD
I actually had a Voxhorl Cavalier years ago with an aftermarket sunny (might have been a Britax? don't quote me) but I'm struggling to remember what use it was to me? I think I used to set it 'open' at a jaunty angle or if you felt a bit racy it would remove completely and give olympic-sized buffeting in the car. Are they supposed to extract hot air from the cabin as you drive I guess? car sunroof's eventually got laid to rest when a/c became the norm although 'Panoramic' roofs seem all the rage now.
- DaiRees
- Site Admin
My Suzuki had an aftermarket sunroof in it's removable hard top
. It had been sealed with lashings of clear silicon and leaked like a sieve when I first had it, after a bit of fettling it was fine and never leaked again.
The Volvo is the first proper car I've had in 15 years or more that doesn't have a factory fitted sunroof, I don't miss it at all. Occasionally opened the one on the Pug but that was for novelty factor more than function.
DaiRees wrote:My Suzuki had an aftermarket sunroof in it's removable hard top![]()
The sunroof in my car is great. I get the fresh air and ventilation,
but without all the wind roar of opened side windows.
2006 Toyota Yaris 1.0 T3
1993 Mazda MX5 Mk1 1.6
The sunroof is a bit of a gimmick, but nice to have on the 406 as the cover slides over it so it doesn't cause any annoyance. The 305 on the other hand had an alfa romeo sunroof installed, apart from the fact it doesn't really fit in with the grooves of the roof, it was impressive that it didnt leak.
But it was a bit rubbish, it only popped up about 2 inches, and my dad who has a bit less thatch on the top of his head had to wear a hat while driving the car on a sunny day to avoid getting sunburn.
