Location of intake to air recycle in cabin
Hello
Since my car is a bit smelly I would like to refresh the A/C and heater system. Can anyone tell me the location of the air intake when I choose to recycle the air from the cabin?
Thank you!
Thank you!
1987 Peugeot 205 1.9 GTi 8v
1999 Peugeot 406 2.0 HDI ST estate
Re: Location of intake to air recycle in cabin
It's under the pollen filter (I'm suspecting that's gonna be your problem as the flap is obvious once you remove the filter to change it...)
Pollen filter how to, courtesy farmerpug - http://youtu.be/wa3OeeKmSOU?t=12m49s - I guess yours is going to be a left-hooker so it's a mirror image on the other side.
Maybe I did not explain it properly. There must be an air intake inside the car to suck in the air and recycle it, right?
Not 100% but the other halves 307 has it in the drivers footwell area, try and lie with your head by the pedals and get someone to press the recirc button and you might spot it moving.
I will try to observate the driver's side. Thank you!
Oh, I get it, sorry. I thought if you knew where the flap was... It's actually right there, on the top of the motor. The bit above the motor is open at the front for for fresh air and behind for recirculate, the flap just swings between the two.JensJakob wrote:Maybe I did not explain it properly. There must be an air intake inside the car to suck in the air and recycle it, right?
You can see it right at the start of this vid http://www.youtube.com/watch?v=yJ62x1zU ... e&index=64 (farmerpug strikes again
Ah, sorry. My bad
It makes sense with that construction. Thank you so much!
- Rolebama
On mine, the intake vent for recycling is on the offside panel in the boot.
1998 2.1 GLX TD
- markw
I have that too, but I thought it was more of a pressure equalisation thing....to prevent the other windows trying to pop themselves outwards when a door is slammed!
I thought it was both sides?
Anyway, that's for normal ventilation, otherwise air sucked in by the blower would pressurise the interior of the car. On recirculate the air inside the car is just blown around and around.
- markw
Yup, it has a hinged flap on it that only lets air out, not in.
For years, I wondered what the 'click' was that could be heard from the boot area when a door was shut....it was the flap opening and closing.
