Hi, my rear centre seat belt is knacked, can I use a seat belt from another model eg.306, or must it be a 406 ?
I need to to sort this out soonish as my MOT is due in May. (Not too good with mechanical stuff, numbers are my thing)
406 estate - centre seat belt knacked
- lozz
Re: 406 estate - centre seat belt knacked
Hi,
306 rear seat belts adiffernt ibelieve, hopefuly someone else here will confirm
if you need a mot loophole,re: rear seat belts, mot testers carnt inspect rear seat belts if a child seat is in place,
is it knackered or jammed locked with seat folded down?
My other Peugeot was a D4B
The seatbelt is locked but the seat is up, I have removed the bolt underneath the seat to slakenD4B wrote:is it knackered or jammed locked with seat folded down?
off, but I will need to replace it.
Here's a complete rear seat probably wrong colour though....
http://www.ebay.co.uk/itm/1999-PEUGEOT- ... 51a802ff2d
Just goto a local breakers and get a 306 labels that's what I've done
Les medecins choisissent www.viagrasansordonnancefr.com traitement efficace
