Hello,, I'm hoping someone can help me. Recently bought a 406 coupe, which i'm loving, but the carpers In the back are soaked through. Whilst trying to dry them out I heard a lot of water leaving the car (I was stood on a towel to absorb the water) from the underside.. Had a look and what appears to be a plug hole was there,, but with no plug.. Stuck my finger in to feel the carpet right there. The other side, though wet, still had the plug. Where can I buy new plugs for the holes so the water stops getting in?? And are they expensive?? (can't find on eBay or anywhere) I looked at the ones under the rear seats, still there too, but the rubber is corroded.. Need to replace the lot.
... Hopefully someone can help me ☺
Rear footwell wet
Re: Rear footwell wet
Main stealers or the scrapers I'd of thought
2006 BMW e61 535d m-sport
run's for cover
Maybe they were removed to let the water OUT..??
You can use duct-tape instead, which can be peeled back to ' vent ' the car if needed.
