STEERING WHEEL REMOVAL
Posted: Sat Dec 14, 2013 11:43 am
I HAVE removed bolt in centre of steering is that all thats holding it on?
it is more stubborn than last time .
thats a bit understated .....pull like f*ck whilst wiggling hard,then watch you dont smack yourself in the face when it finally gives inoldskoolskool wrote:Yep, just wiggle it around a bit and pull.
Takes all the fun/suspense out of it if you do that tho Steve............................steve_earwig wrote:Good lordTurn the nut on a few turns, then it can't come off and break your nose.
^this. Much easier to pull hard if you're confident that you'll keep your face in one piecesteve_earwig wrote:Good lordTurn the nut on a few turns, then it can't come off and break your nose.
