Bumper and wing
Tonyw650
Bumper and wing
Post by Tonyw650 »
Hey Guys,
I had some one reverse into my 406 in a car park recently and drove off!, mines got the pop up head light jet washers, do these bolt to the bumper under frame or to the bumper is self?
then my other question is can I either get a bumper off a 406 that didnt have them fitted and retrofit them or fit a after market complete bumper.
also how easy is the front wings to change?
cheers
Re: Bumper and wing
Hi mate. The jets are screwed to the bumper, and a pain to introduce to a standard bumper as there is lots of plumbing behind it. When I changed mine to a standard bumper I just deactivated the headlight washers with pp2000 and swapped the washer reservoir for a standard one too ( on less hole for motor )
The wing is easy too, look in the knowledge base menu on the forum. My wing took 30 mins to swap and you don't need to remove road wheel to do it, just the liner.
